wannabervinExplorerAug 26, 2014Using an RV in chilly, but not fridgid weatherIs there a way to use a TT, class C, or class A, in the fall or spring, when daytime temps can be quite pleasant, but the mercury might dip below freezing at night? How to avoid frozen (and maybe bus...Show More
stetwoodExplorerAug 26, 2014If the temp is going to be under freezing overnight disconnect and drain hoses, use your on board tanks.
Related ContentAdd a Room in chilly climateEl Nino forecast: Texas ChillyHot weather towingRGV weatherTerlingua Chilli cook off
