- tjfogelbergExplorerWe use a small space heater when we're plugged in. It got down into the low 30s a couple of nights last Fall and we had no problems. Follow the advice given here and you should be fine. Winter camping is something I hope never to do.
- 2012ColemanExplorer IIBe prepared for all the condensation that will form on the windows. Otherwise, no problem - check your propane levels before traveling.
- BarneySExplorer IIIIn addition to all the suggestions above, open cupboard doors to let heat circulate inside the cabinets where the water lines run. You can also let an inside faucet run slightly if you are hooked up to a drain system.
Barney - pastthings2ExplorerI have used a 1979 dodge 24 ft class c in the mountains with a high of 10 degrees and low of -5 several times for 3 days, snowing 24 inches in 24 hours at Mt Hood Oregon. As long as I had furnance on and propane on water heater all was well except corner of bathtub. Used hair dryer to thaw. Kids had a blast sledding. You will be suprised that winter camping is more fun. No crowds. Beautiful when snowing. Put chains on rig (before it snows and you can go anywhere).
- koda55ExplorerWe have a class A and the day after Thanksgiving we head for Pa. We camp in a friends front yard. He runs a electrical cord out to the rv so we have electric without running the generator. We just run the furnace and it keeps tank bays warm and nice and warm in the rv.
- wannabervinExplorerThanks for all the great advice. It would seem that I can use my TT for a few more weeks after mid October, when I would have put it away and winterized it. Especially if I stay sour. TT lives in Woodbridge, VA.
- drillkingExplorerFull timed going on five years now. Coldest winter stays were in Trinidad, CO-12 below, other was Winnemucca, NV- 15/20 below. Had good insulation and used a "Spirit" outside water line. Has it's own built in heat tape and sensor. Thankfully never froze up through those winters! Had fun. We don't worry much where we are at in the winter.
- While in use most any RV is good to about 25 degrees assuming the high for the day is close to 40.
Much lower and I suggest some electric heat where needed.
www.ultraheat.com - JiminDenverExplorer IIOur trailer is a 3 season meaning less insulation, single pane windows and no inclosed belly or heated tanks. We see freezing temps nightly as early as Labor day and as late as June. Some years have seen snow on the 4th of July. We have never frozen up even when the daytime highs only reach the high 30's/ low 40's.
- CincyGusExplorer IIMy general rule of thumb has been if half the day is going to be 40 or above, I don't worry about a thing. Run the furnace and maybe open the cabinet doors so heat can get to the pipes. If it's going to be highs slightly over freezing and everything wont get a good chance to thaw during the day or if it's going down below mid twenties overnight, I'll use a well placed small 1500 watt heater and disconnect my water lines overnight. Camp often in Oct, Nov when night time lows are in that range without issues.
About RV Newbies
4,026 PostsLatest Activity: Jun 15, 2017
