Dakota98 wrote:
I would be sure to investigate the hitch & all related components & determine for sure if they are "factory" or if aftermarket. Check & see if it has a transmission cooler or not. Check the stickers for GVWR & any other information related to towing ability.
I agree with the above. A seven pin connector and a hitch is not insurance the the vehicial has a tow package. A factory installed transmission cooler is a good starting point. The cooler is normally easy to find under the hood in front of the radiator. BUT the only dependable source is the VIN. Look up the VIN and you will able to determine what the vehicle was equipped with from the factory. That's my opinion only.
