brirene
Dec 15, 2015Explorer
vanmol wrote:
Ok! It seems that use what you have freely and empty often is the better policy. Thanks for the info. Frank
Well, not really. Black water tank should be at least 2/3 full when you empty to make sure it creates a "flushing" action. Then empty the gray tanks to flush the hose. Dealer should give you a good walk through when you pick it up. Don't leave until you're comfortable. As mentioned earlier, it's really not as bad as it seems before you actually do it. Good luck, and welcome to the forum!
About RV Newbies
