Kalait's avatar
Kalait
Washing and Waxing
I am looking at pressure washers after hand washing our 21'9" trailer. Please suggest a pressure washer or how is best to clean the outside of the travel trailer.:h
  • You won't need anything over 2000 PSI. My gas powered washer has a series of tips--from foam spray to 0 angle. I use the foam spray tip with the soap injector to put the soap on and a 45 degree tip to rinse. The higher pressure rinse tip should be held a few feet back from the surface. The soap should be doing the washing and not the pressure of the water.
