njtony
Apr 21, 2019Explorer
water heater bypass
After my first time winterizing last fall, I questened the placement of the water heater shutoff and bypass valves. My hot and cold valves are placed before the bypass valve. Is this correct?
kellem wrote:Now that's an interesting point. Once all of the water has been displaced by anti-freeze, that anti freeze can then be drained. Still have to rinse the residual anti-freeze come time to start camping again, but...
On a side note:
Something I always tell other RV's and friends I actually winterize for.
As soon as you winterize your trailer you can instantly de-winterize and return all valves back to operating position as all your really doing is displacing water.
Yes,I'm saying run RV antifreeze through all the lines then simply drain it back out.
Been doing like this for over 20 years.
