njtonyExplorerApr 21, 2019water heater bypassAfter my first time winterizing last fall, I questened the placement of the water heater shutoff and bypass valves. My hot and cold valves are placed before the bypass valve. Is this correct?
kellemExplorerAug 07, 2019Yes,my apologizes for derailing thread.It helps the less experienced to return all cutoff/bypass valves back to there home position while memory is fresh.lolPrevents frying an element in the spring or asking " what happened to my water pressure ".....yes some rinsing required.
Related ContentAtwood water heater problemWater Heater bypass valve.Smelly Water HeaterWater Heater Replacement RecommendationsWater pump?
