miyzfrider's avatar
miyzfrider
Water Heater Control (Electric and Gas)??
On our new TT, our Suburban hot water heater is both gas and electric. Electric switch is out on the unit itself. Then we have a switch inside the TT, which I understand controls the LP function. However, what I'm not clear on is how the two interact with one another? In other words, if I pull up to a campsite, have the HWH filled with water, kick both switches on, will the LP light as well as the electric element kick on? Once the water is at temp, will the electric take over and run instead of the LP if both switches are on? Is the switch inside a "master" switch, so if I shut it off, will the electric also shut off? So in a typical camping situation, with a full HWH, should I just leave both on?
I'm just not clear how the two controls work together, or are they 100% separate from one another? The manual doesn't really say much.
Thanks!
