RedRocket204
Jan 18, 2017Explorer
ksten wrote:
Yes, the tank drain valve. That's what I'm trying to find. I've looked at the paper manual, and the online PDF manual, but the only mention they have for the drain (even after text searching the whole document) is:
1. Drain the fresh water tank.
Nothing about how that's supposed to happen, or where the actual valve is :/
When you filled your fresh water tank, was there water immediately flowing onto the ground from somewhere under the trailer? If not and the water only came out after you were moving, then your fresh water tank drain valve is closed and the advice given about the vent creating a vacuum is what you should be looking into.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
