dewey02
Jan 18, 2017Explorer II
RedRocket204 wrote:x2
When you filled your fresh water tank, was there water immediately flowing onto the ground from somewhere under the trailer? If not and the water only came out after you were moving, then your fresh water tank drain valve is closed and the advice given about the vent creating a vacuum is what you should be looking into.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
