Acampingwewillgo wrote:
I know this has been covered several times but if your in the market for a "GOOD" regulator, E-bay has the Watt's N55(?) for around 42.00 dollars now. Its preset at 50 PSI although the one I just purchased is more like 42-45 PSI after passing thru my in line filters. I replaced an older Watt's model(H560) and I'm expecting a much better volume/flow of water with this new device....I'll let you know, have not used it yet.
yep throw away the $9.00 walmart special and get a decent regulator with a decent flow rate. if you have to have/use a cheapy, just buy a second one and put them in parallel to double flow.
bumpy
