- path1Explorer
TruckinRVer wrote:
Should my water pressure regulator be in line before or after my water filter?
Mine doubles as turn off knob on top of stand pipe - DutchmenSportExplorer
Old-Biscuit wrote:
After a $6000 repair due to $0.50 fitting breaking and RV getting flooded I no longer stay connected to 'city water'-----use the pump exclusively
This is exactly why I do the same thing. I never hook up the hose to the fresh water inlet. I always fill the fresh water tank and pump from there. And .... I've never had problems doing it this way either.
But, for the OP, if you are going to use a regulator, put it on the spigot. Hopefully, if it fails, your garden hose will blow before the pipes in your camper does! - old_guyExplorerI put mine on the faucet. I got up one morning and my hose looked like it swallowed a pig.
- wa8yxmExplorer III
Park Regulator, LONG hose...
IF you use an external filter,, Filter and short hose, Keep filter OUT of sunlight
RV - naturistNomad III'd put the pressure regulator in the line before any of my stuff that I didn't want blown up by the high pressure the regulator is supposed to protect you from. This means at the hose bib from which I draw water, before my hose/filter/trailer inlet.
I learned this lesson the hard way. I once ran my white drinking water hose from the hose bib to the regulator, then into my trailer. Turned on the water, looks good, not even a drip, so I go inside to get an icy cold one, and glanced out the window to see water spewing from the bib/hose joint. The pressure was so high it split the hose right next to the fitting.
This lesson came in handy a year or so later, when I camped at a campground that was located on the side of a mountain. They put me in a site at the bottom, where the water pressure, had it been merely 20 psi nominal up at the lodge beside the highway whence the water supply was located, would have been boosted substantially in the course of coming the 300 feet or so DOWN to where I was located. Guy across the way from me split his water hose. - Yeti_plusExplorerI put my regulator right at the trailer or camper.
When the hose sits in the sun the pressure increases. The hotter the hose, the higher the pressure, so the pressure in the RV goes up if the regulator is at the spigot. If the pressure goes up in the hose with the regulator right at the RV and the hose breaks no big deal , just buy another hose, or a mending kit. There has been no high pressure in the RV.
Brian - bikendanExplorer
Sandia Man wrote:
I mount my adjustable water pressure regulator directly to spigot, our water filter is located inside our rig.
x4 - TruckinRVerExplorerThank you for the info so far.
- Old-BiscuitExplorer IIISAME^^^^^
WHEN I use a regulator it goes on spigot then a 'wye' with shutoffs.
Potable hose then filter
Garden hose on other side of 'wye' for general use
And 'WHEN' I use a regulator is just for filling fresh water tank.
After a $6000 repair due to $0.50 fitting breaking and RV getting flooded I no longer stay connected to 'city water'-----use the pump exclusively - ScottGNomad
X2.
May as well protect everything.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
