GordonThree wrote:
That's all the sensor is ... the device that attaches to the studs reads resistance / conductivity and turns the full, 3/4, 1/2 and 1/4 lights on.
You could also look at upgrading to the Seelevel II system, which attaches via a sensor strip to the outside of the tank and is more precise.
thank you Gordon, so to clarify, do i need actual sensors which attach? or just a wire and bolt to the female thread? even o look at sensors on line i see a sensor and rubber grommet etc as if i was going to drill a new hole and add that.
can you point me to a photo of what i might need?
thank you
