Andrusha wrote:
GordonThree wrote:
That's all the sensor is ... the device that attaches to the studs reads resistance / conductivity and turns the full, 3/4, 1/2 and 1/4 lights on.
You could also look at upgrading to the Seelevel II system, which attaches via a sensor strip to the outside of the tank and is more precise.
thank you Gordon, so to clarify, do i need actual sensors which attach? or just a wire and bolt to the female thread? even o look at sensors on line i see a sensor and rubber grommet etc as if i was going to drill a new hole and add that.
can you point me to a photo of what i might need?
thank you
The nails you spotted are the sensors. There the bottom one is probably ground and the others are the various levels.
The SeeLevel system just attaches to the side of the tank like a big sticker and does not use the original sensors. There are no holes drilled in the tank with the SeeLevel sensor.
