Bobbo wrote:
It wouldn't be illegal, just one more step. It's there for a reason. The reason is to keep the pump from pumping your water out of it.
I agree, you may be able to repair it, but new ones are cheap and replacing it is simple. Unscrew the fixture from the side of the RV, pull it out and unscrew the old valve. Screw in the new valve. Screw the assembly back to the RV, and caulk around it. Done.
Are you saying just take out the city water inlet washer and repair or is it the one inside the trailer there are pictures of both.The water pressure is fine it's just when I use the water pump the water shoots out the city water inlet
