jffnkrn
May 17, 2015Explorer
My experience and doesn't mean I am an expert. Towing for over 18 years and still learning. Had TT in the past and always, always had Eight distribution and Sway control. Chain type draw-tight and also Equalizer II. I would swear by the equalizer II. It is not only weight distribution but also sway control. Weather you have a TT that is perfect weight for the tow vehicle, you may be at max or near capacity or capacities at times. This in addition to windy conditions, passing large vehicles etc, you will be happy with a weight distribution / sway control. My experience, Equalizer II was the best money I spent. you will spend about $400 to $500 depending on the unit, size etc. Follow the directions, do it yourself or make sure dealer installer is doing the measurements etc all correct. Go onto the Equalizer II website, watch the video and decide. Talk to a few folks, Again, for me the equalizer was easy to install, use and functioned very well. Had about 28 or so thousand miles on it. Do your research, talk to people and decide. Good Luck & Be Safe ! ! !
About RV Newbies
