Chaz59 wrote:
When I originally got it set up at the dealer a few months ago, both sides seemed to have the same amount of pressure.
Thanks for any help you can offer.
You have figured out the bar tension, but getting a dealer to install and set up a WDH is not good. It's a really good idea to learn how to do it yourself. The dealer may not have properly torqued nuts/bolts, the bars at the right angle, the correct number of chain links under tension and there may not be the correct amount of weight transferred to the steer axle.
There is an excellent sticky on WDH setup in the towing forum.
