Chaz59's avatar
Chaz59
Weight Distribution Hitch
When hooking up my weight distribution hitch chains, I have a lot more tension on one side of the hitch, than I do on the other side. When hitching up the chains with the tension bar, one side is very easy to flip the lever up with the bar. There is no 'real hard' tension. The other side has a LOT of tension. Is this normal?
When I originally got it set up at the dealer a few months ago, both sides seemed to have the same amount of pressure.
Thanks for any help you can offer.
  • When you hook up...are you parked in a straight line...? i.e. is the tow vehicle and trailer straight on with each other?
    If parked at an angle, one side will have less tension.
