JoshuaH
Jul 11, 2018Explorer
What do these valves do on my pump?
We just bought a Hybrid trailer a few weeks ago, finally had some time today to look over the pump system and learn how it works. There are 2 valves that I'm not sure what exactly they are for.
One valve has a clear hose that connects to nothing, it was open and as I started filling the tank with water, water started coming out of it so I closed it. I assume this is some kind of vent? When should this be open and closed?
The other is in line with the hose that connects to the bottom outlet on the tank, I assume you close this valve so the tank doesn't fill with water when you are connected to city water? And of course open it when you are using tank water?
Thanks!
Thanks!
