JoshuaH's avatar
JoshuaH
What do these valves do on my pump?
We just bought a Hybrid trailer a few weeks ago, finally had some time today to look over the pump system and learn how it works. There are 2 valves that I'm not sure what exactly they are for.
One valve has a clear hose that connects to nothing, it was open and as I started filling the tank with water, water started coming out of it so I closed it. I assume this is some kind of vent? When should this be open and closed?
The other is in line with the hose that connects to the bottom outlet on the tank, I assume you close this valve so the tank doesn't fill with water when you are connected to city water? And of course open it when you are using tank water?
Thanks!
  • Water heater bypass for winterizing. Makes it possible to fill all the pipes with antifreeze (takes a gallon or so) without having to fill the water heater (which would add 6 more gallons to the antifreeze needed).
    It's for winterizing - just turn the valve so it's open, stick the hose in a jug of antifreeze, turn on the pump, and it will run antifreeze through the water system.
    In most cases when the winterizing valve is open it also closes the draw tube from your fresh water tank - without pics (can't see yours) it's hard to tell but I'd suspect this second valve does just that - close it for winterizing but open it for the rest of the season. The pump itself has a check valve to prevent city water from entering the tank so another shouldn't be necessary.
