schlep1967
Nov 18, 2019Nomad
dodge guy wrote:
When I had my trailer I didn’t even drain the lines. I ran water through the system until it all came out pink. Never had an issue. If I’m not feeling lazy then I’ll pull the low points and drain, otherwise I just run the pink through it.
If your low point drains are valves above the floor line you can get away with this. If they are caps below the trailer, do yourself a favor and drain them. If you don't there is a good chance you will have nothing but water in the lines hanging down. No antifreeze. When those caps freeze and crack you will have a problem next year.
About RV Newbies
