Yosemite_Sam1
Nov 18, 2019Explorer
Seriously this time, I would suggest you run the pump while all faucets are turned on or open to drain all water in the lines. Then open the low point drains.
Do these again after you've loaded the 4 to 6 gallons of RVC fresh water anti-freeze.
Others suggested blowing air to purge all water inside. I just installed a water accumulator and indeed there are bent pipes where water can accumulate, freeze and crack.
About RV Newbies
