Rmack1
Nov 21, 2013Explorer
scbwr wrote:
We just went through the process of looking/purchasing a smaller, lighter travel trailer and we spent a lot of time looking at a lot of trailers from many manufacturers. We were hoping to buy a higher end trailer, which seems to be hard to find. We looked at Jayco trailers because of their two year warranty, but found that their light weight trailers had a few shortcomings. We ended up buying a Winnebago Minnie 2201DS http://winnebagotowables.com/models/2014/minnie/2201DS.jpg
Reasons for purchasing:
1) length @ weight met needs - I wanted the trailer to weigh under 6500 lbs. fully loaded.
2) compared to others, fit and finish was better.
3. Ducted AC & heat.
4. More storeage area than any other trailer of same size...great wardrobe and storeage cabinets in bathroom.
5. Corner shower w/door.
6. Outdoor kitchen....very nice feature for the way we like to camp.
7. Maximum lenght awning (19'). Jayco is putting shorter than necessary awnings on many of their light weight trailers.
8. Smooth exterior walls...they're laminated with fiberglass on the outside. Winnebago doesn't really provide any details on their wall construction but so far, I haven't experienced any problems. With laminated walls, I know that I'll have to be diligent about maintaining lap sealant, but my trailer is stored inside when not in use, so that really helps.
9. And, the floorplan is one that meets our needs.
10. Really like the electric awning!
After purchasing the trailer, we took it to the factory to have a roof ladder installed, and factory service was excellent. I've only had a couple of minor issues....some plumbing fittings weren't adequately tightened under the kitchen sink and the kitchen faucet had to be tightened.
But, everyone has their own preferences, so all you can do is look at a lot of trailers and find which units meet your needs and then compare construction and quality of materials.
good luck!
Doesn't have a full couch when the bed is folded up, like if there was a 'Murphy bed'.
Plus, you wouldn't have to gain the floor space with an expensive, heavy, problem-prone slide-out.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
