wbwood
Jan 09, 2014Explorer
Terryallan wrote:
The answer is. Get what you want. You are the only one you have to please.
Agree 100%. First I would not even make a decision based on costs. I would go with what you will want. You can get truck/5er cambos for the same price as Class A's. You can get some Class A's that are cheaper and more in line with teh truck/5er combo price.
5'er Pros
- Normally larger inside
- If truck brakes down, you can how 5'er towed to campground and stay in it
- Truck serves as a toad
5'er Cons
- When parking it at campsite, there is more to setting it up outside generally than a MH. Weather can be an issue
- Sit up higher, therefore more steps to get inside. Then once inside, even more steps.
- Have to go back outside to hook the truck back up.
MH Pros
- Fully self contained. Pull in anywhere and all the controls are inside. Can turn on generator from inside
- Less steps over all in general.
- Easier to stop somewhere and rest.
MH Cons
- If you want to get around, you wsill either need a toad, a rental or pack everything up and drive the MH (which can cause other issues).
- If you have a toad, then a second motor to care for.
- If MH breaks down, then your sleeping quarters are gone with it.Sometimes they will let you stat in it overnight at mechanic shop, but who really wants to do that?
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
