schlep1967
Mar 29, 2021Nomad
jimbo4UT wrote:
Guys here is what I know. Opened the black tank turned on the water and a slow stream came out of the sewer hose (water was clear) the other side of the rv were you gravity feed the fresh water tank it was pouring water out of it. That’s all I know
Jimbo
With the info given above I would guess somebodyinstalled a flush kit and put it into the wrong tank. If this is a new unit contact the manufacturer.
If it is used you can try the manufacturer but odds are they will tell you the previous owner self installed a flush kit into the wrong tank. If that is the case properly lable it as a fresh water fill port, sanitize your freshwater system as you should every year and move on.
About RV Newbies
