wopachop
Mar 30, 2021Explorer
jimbo4UT wrote:Fun to troubleshoot. Are you saying that you opened the black tank valve first, no water came out, then you turned on water pressure and saw water begin to exit the black tank?
Guys here is what I know. Opened the black tank turned on the water and a slow stream came out of the sewer hose (water was clear) the other side of the rv were you gravity feed the fresh water tank it was pouring water out of it. That’s all I know
Jimbo
That would go against my first thought. My best guess is that there was already a small bit of water in the black tank. You opened the valve and saw water come out. But if water is exiting the fresh water overflow, while you have water pressure turned on, then it must mean you were hooked up to the fresh water fill. Crazy part is you claim the fresh water fill is on the other side of the trailer.
Maybe the plumbing line of the black tank flush has a small leak. You might have been flushing the black tank at the same time youre leaking water onto the ground.
Are you positive the fresh tank was full? I think you said that you drained the fresh tank. Did you literally dump 100 gallons on the ground? Not making fun, just trying to figure out what we can call facts.
The dealer must have prefilled the fresh tank for you?
About RV Newbies
