Dutch_12078
Dec 13, 2013Explorer III
SCVJeff wrote:
Someone has likely done it here, but I think if you were to add a router/ repeater where you sign on through it, the host sees only one MAC address and you might be able to get around it.
Yep, the "PayFi" TOS usually says something to the effect, "Only one device may connect using each code.", but if that "one device" is a router/WiFi repeater like some models from Cradlepoint, Pepwave, and others, then multiple other devices can in turn connect to that "one device". Legal? Probably... Circumvents the spirit of the TOS? No doubt...
About RV Newbies
