NorCal_Dan
Dec 21, 2013Explorer
@wittmeba - That's true - in that situation the CG is not restricting access to guests - they are just making sure non-guests do not piggyback their WiFi.
@dbwiddis- If you don't want to get into this situation again then being able to use one access device in your RV to share that connection with all your devices is the best answer. You would only need [to pay for] one access code.
Can you use a router? Unknown.
If the CG WiFi is open, meaning anyone with the [WPA/WPA2] "key" can connect, then a router will work. But...In a "closed" WiFi system, to get internet access, the system will re-direct your browser to the CG page where you will input your login/pw.
I am not aware of any router that can be used this way...
About RV Newbies
