brirene wrote:
^^^^You should be fine with that, especially with daytime temps that high. Open a few cabinet doors to allow heat to get to pipes better.
Ok I decided to just go ahead and put in the pink stuff.  I used 2 gallons, don't know if that is normal or not.  I figured 2 gallons of pink stuff was cheaper than running space heaters 12 hours a day for 3 weeks.  There sure was a lot of crud that came out of the water heater, I guess I should drain it more often than every 5 years.  Should I drain the fresh water take also?  It would take a long time at 28 deg to freeze 20 to 30 gallons of water, I think.
