- DutchmenSportExplorerreddog24,
You have experienced a trauma, and the fact is, you may NEVER completely over come it. Years ago, when I was 16, I had an encounter on my motorcycle. The motorcycle when one direction (right into the corn field), and I went the other way, right down the middle of the road! Between lots of skins, road tar that tatooed into my skin forever. I was able to ride the motorcycle home with twisted handle bars, a severely leaking gas tank, and blood gushing from every spot of my body. A trip to that old man that delivered me at birth taught me a lesson by washing those wounds with alcohol and scrubbie, and NO I was not under any sedation. He did that to teach me a lesson. He despised motorcycles and wanted to put me in enough pain I'd never ride again..... WRONG! I did!
Why did I tell you this story? Because every time after that I attempted to get on another motorcycle, I had a real bad case of "nerves" and the closest sit-down bathroom was all I could do! Oh, I rode again, but the "nerves" thing is something I never got over. Funny, I quit riding completely at age 29, and even today, just to look at a motorcycle make me have to "go!" (if you know what I mean!).
Will you ever overcome your emotional trauma? Maybe not! And if not, I think that's OK too. You'll just have to accept your limitation now, and look for a different method. Perhaps you will never be able to drive again. You may even get to the point where you are not even able to enter the motor home without having panic attacks. If this happens, you'll just have to change your life style.
I'm sorry this happened to you, but you don't need to beat yourself up any more feeling bad. Just accept your new limitation and look for an alternative way to be happy! It might mean changing RV's or even going to a -truck-trailer combination, or give up the RV life style completely. Only you can answer that. But it's REALLY OK, and you'll eventually be OK too once you find your 'way'!
EDIT... I'm sorry, drinking alcohol NEVER solved any problems! Hiding a root cause by smothering it with alcohol will only turn you into an alcoholic. Now you'll be a traumatized alcoholic. Alcohol is NOT the answer! AND there definitely is no smiley after this sentence! - dalehelmanExplorerJust take several short drives. That will help you rebuild confidence. In time you will be able to relax and enjoy your new RV again.
- pianotunaNomad IIIHi reddog24,
Go for a drive to an empty parking lot. Take along some cones, and practise lots. Start at 5 mph. You will be fine--just as you were in the 21 foot. It will take a bit of time, that's all. (We believe in you!) - RVUSAExplorer
Steve S wrote:
WOW you guys are a tough crowd! She's asking for advice so she's not afraid and not having anxiety attacks.
K my best advice is to hit the bottle, I find drinking hard and heavy helps to deal with many problems like the ones you're facing.
I hope this helps!
When you fail to add the smiley, your post reads as serious advice. Are you seriously suggesting they drink and drive? And that you also drink and drive in order to handle this kind of situation in case it arises?
:B - Francesca_KnowlExplorerI'm not understanding the Original Post- were you belted in the passenger seat or somewhere in the back of the RV?
If the latter:
You probably wouldn't fear riding in the cab of a pickup just because you got tossed around riding in the pickup's bed- you just wouldn't ride back in the bed anymore....right?
Try thinking of this the same way- just don't get out of the seatbelt unless the rig's not moving, at least for now.
Good luck! - okiejoeExplorerWhat you might try is adding a steering stabilizer shock system and just remember if your tire drops off the pavement back off on the throttle don't brake, get control (your first reaction is going to be to jerk it back on the road) just get control and continue going straight and gently easy it back on the road. Many peoples first reaction is to panic and jerk it back onto road and hit the brakes this causes many problems. Braking adds more weight shifted to front tires which make it harder to control tire in the dirt. One other key thing to do is don't stare 2 to 3 cars in front of you, you need to look as far ahead as possible, what this does is keep you centered in the lane, its when you only look ahead just a few cares or even a few hundred feet you will find you will drive to one side or the other. Find some real good wide road and drive it a lot to get used to it, don't give up, you will gain your confidence. One more thing I would do is add some really good shocks to it to reduce any rocking or swaying. There are some very good systems to improve the steering it just takes some research.
- loulou57ExplorerTake it out again on small trips and increase the time, miles and the amount of traffic until you are at ease. It will happen.
I was in a head on accident in the snow/ice. We actually were almost stopped. We saw the car coming but had nowhere to go. Traffic on the left and snow bsnk on the right. It was an awful feeling watching that car coming faster towards us. Anyway, it took a while but I now am ok being in a car in the snow.
Don't give up your dreams or your RV. Obviously, your hubby corrected thing, straightened out and drove home safely.
Go out and enjoy. - GaryWTExplorerSlightly confused, did you end up on your back or you were in the back? I say sit in the front, less movement and a better seatbelt. Also if you see things then you can be ready for them.
- CroweExplorerPractice, practice, practice, close to home. What I found very helpful is the use of industrial parks that have roads. You may have to contact the owner of the property for permission but that gives a little more "real life" to the driving. Not sure there's an RV school up here in the northeast but maybe a tractor-trailer driving school can help. It took some time for me to get used to our Endura when we had it but like anything you just keep at it.
- reddog24ExplorerThanks Steve S, I was thinking the same thing. So much for a friendly group of folks. I certainly hope nothing ever happens to any of you and you need advise.
Looking for advice before your next adventure? Look no further.25,108 PostsLatest Activity: Feb 02, 2025
