ASCTLC
Mar 02, 2018Explorer
I do exactly as wowens79. I chock the back of the rear set of tires (both sides), back up a tad more to add a bit of pressure to those back chocks and set the park brake (if by myself), then chock the front of the front tires.
The cradling adds enough pressure (if you back up enough) that the suspension doesn't bounce at all and the side to side twisting around that center is eliminated. I do that first then I tighten my side to side DIY frame stabilizers (front and back).
I learned to do this with my wide spaced axles that x-chock type products don't work well with, and aren't any more effective than the cradling effects.
Andy
Andy
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
