Bucky_Badger
Nov 30, 2016Explorer
SoundGuy wrote:korbe wrote:
I was attempting to explain to the OP that if he used larger sized lines that did not increase head loss or friction, then he would not be increasing the strain on the pump. Boy, do you always enjoy being so critical? :R
I merely posted what the Flojet owner's manual recommends for hose size ... what's "critical" about that? :h. Obviously an owner can use whatever hose they want but it's not recommended by the manufacturer nor is pumping any further than 50'. Any hose with a diameter greater than 3/4" would have to be adapted to screw on to the Flojet which has standard 3/4" GH male fittings.
SoundGuy is correct. The flojet has a garden hose fitting in it so using a larger hose is useless.
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
