klutchdust
Mar 20, 2018Explorer II
j-d wrote:
It has a six-hole pack and missing on #5 only...? Is this one of the "waste spark" systems where a Six would have a Three-Coil Six-Hole pack? Parts lookup shows that. Usually when one cylinder misses with a pack like that, so does the opposite one in the firing order, the one connected to the opposite side of that one coil out of the three in the pack.
Is this the setup you have? Is the engine a V6 3.6L PentaStar? I'm wondering if the sparkplug cables reach, could you switch them, and see if the problem migrates from #5 to its opposite #6.
We nearly scrapped a Subaru where a NEW coil was dropping two cylinders. Another NEW coil and it was back to its old self.
Please send the Engine's Name, Model Code, and Displacement. I want to try this on another forum.
The 08 were pre pentastar engines, I have the 3.8 . When checking the coil The resistance values on the primary and secondary were consistent with one i checked at the local auto parts store. Something is failing after the jeep warms up or is driven long distance like freeway driving.
Counting the original coil, this jeep is on number 3. The first two that failed showed a low resistance on the coil pack. Setting the meter to 200 ohms I checked the primary coils and they read 1.9/1.0/1.9. Ahaa I said, one is reading lower however the new one reads the same thing.
I may just buy a new coil as the history of this Jeep has shown it eats coils. I am missing something, I need to start at square one again. The spark plug wires are so short I can't swap over to check.
I have read a lot of posts on different forums and the results have been all over the place, bad plug, wire, connector. I'll keep trying, thanks to all that have offered opinions, all good suggestions.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
