j-d
Mar 20, 2018Explorer II
Does it sit there and miss at idle, when you can dink with it, like unplugging the injector connector and seeing if that makes a change? I wish we could narrow between Ignition and Fuel before going all out on Ignition.
I don't have any of these, but you can get a "Noid Light" that plugs where an Injector connects. Doesn't tell you injector efficiency, but at least confirms the PCM is pulsing the injector.
Comfort amid Frustration: Coil is probably less expensive than a diagnostic hour at a shop.
It'll be a little while but I'll start a thread in automotive to see if anybody has a tip.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
