klutchdust
Apr 13, 2018Explorer II
Gjac wrote:
Did you ever find the problem?
I did and I forgot to post the results. I found a hairline crack in spark plug #5. I changed the wires and plugs as part of a regular maintenance issue and #5 was the last plug to remove. I looked at it and it seemed ok, with dirty gloves I wiped around the plug and the dirt/grease went into the crack and exposed the problem. The Jeep runs fine now. I do have a new scanner now that I was hesitating to buy for whatever reason, I carry one in the coach when I travel.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
