John_Joey
Mar 12, 2015Explorer
...snip... I used an elastomeric latex coating on the roof.
If you do go this route be careful on the product you buy. Many will not handle standing water and will slowly dissolve. These are normally the places that leaks will form in the first place, not the high spots.
I tend to agree you more then likely have an aluminum roof. If that is the case then you should be able to use the silicone roof coat to your advantage after a good prep job.
FWIW, this is the product that the two fellows used in my park. Clicky.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 30, 2026
