docsouce's avatar
docsouce
Explorer II
Feb 11, 2023
1/2 Inch Drive Corded or Battery Impact Wrench
Primary use would be to change a flat tire when I'm on the road. If I get a corded wrench I would need to start the generator to use it. I would also need an extension cord. If I get a battery operated wrench all I need to do is make sure the battery is charged. Corded Pros: less expensive, takes up less room and I think it would more powerful than a battery operated gun. Cons: need to have the generator running to use. Battery: Pros: ready for immediate use. Cons: takes up a little more storage space, must be charged to use, cost more and this is just a guess, doesn't have the same power as a corded gun. My current set up is a 3ft length of 1 1/2 pipe and a 3/4 inch breaker bar which will work fine but I'd like to simplify my approach.
As always your opinions are valued.
  • If you need the power, a quality Dewalt 1/2 in 20V battery powered will have way more power than a similar corded model.
    Yes, a quality 20V will hold a charge for a long time, while just storing. It will give near max power, right up to the end, when it gives it up.
    Many HD trucks have a lot of torque on the lug nuts. It should be stated in the owners manual, that the pitiful factory supplied lug wrench may not be sufficient. A breaker bar with HD socket and necessary cheater will work for the amount of times that most of us have a flat on our TVs.
    Jerry
  • If I literally was only going to use it for the occasional flat tire and have a generator always within reach, a cordless is a big waste of money.
    But a quality 1/2” cordless impact will hit as hard or harder than the best 120v or air gun of the same class.
    If a person doesn’t use power tools much the cost of going cordless is kinda steep since the convenience of the tools is infrequent. If one uses typical mechanic/construction/carpenter power tools very frequently the convenience of cordless is awesome.
    I just bit the bullet a year or so ago and upgraded from my old cordless drill, driver and baby skilsaw to a new pretty complete set of tools. I don’t touch my corded or air tools very often anymore….
    Only air tools besides paint guns I’ve used since getting the kit is the DA and polisher. Because I don’t own the cordless versions yet! And occasionally 1/2” air impact. It’s “more gentle” than the cordless on nice lugnuts.
    I’m trying to resist the urge to spend a bunch more money on other cordless tools that I don’t “need” as often.
  • Sandia Man wrote:
    newer batteries hold power for long periods of time, more than likely you will still have plenty of power remaining in the battery when called into service.
    True. Li's ( I believe they're all Lis) hold a charge for a long, long time.
  • X2 on cordless 1/2 inch impact wrench, Santa brought me a Rigid last Christmas and already tackled a few projects on our class A with astounding ease. Sure gave my right arm quite a work out as it is pretty heavy, but removing bolts that would have required serious muscle, literally in seconds, don't know why I did not get one sooner. Tried the electric AC driven 1/2 inch and it just did not have the torque, probably why I didn't pull the trigger on the 20 volt version sooner thinking they have similar power. These newer batteries hold power for long periods of time, more than likely you will still have plenty of power remaining in the battery when called into service.
  • Cord-free is my choice. Hopefully you never have to change a flat on the road.
  • Actually the cordless will likely take less space than the corded. A Dewalt 1/2" cordless impact will be more than equal to a corded impact. They do cost more, but you can usually pick up a used one off Facebook Marketplace for a very good price. The corded impact really has only one possible plus: a new one is cheaper than a new cordless. But if you go used, that's a wash.
    IMO a cordless assets totally outweigh the corded assets. No contest.
