CavemanCharlie's avatar
CavemanCharlie
Explorer III
Nov 20, 2017
12 volt heated blanket
I found a 12 volt blanket here.
https://www.amazon.com/Trillium-Worldwide-12-Volt-Heated-Blanket/dp/B0000DYVN9/ref=as_li_ss_tl?ie=UTF8&dpID=41k3kSfNSKL&dpSrc=sims&preST=_AC_UL160_SR160,160_&refRID=0C24CR7WZ37922JC3ESY&linkCode=sl1&tag=homesteaderneewssolar-20&linkId=830400d141f7f382186c4c36716535f6
It takes 50 amps but, it is only turned on for 30 to 45 minutes on a timer. Has anyone ever tried one of these out ?
I wonder if it would be worth it in my Travel Trailer when I am dry camping and using my 2, 6 volt deep cycle golf cart batteries ? I could warm up the bed with it as I go to sleep and then use my body heat to keep it warm after that.
I will be going out this Saturday night. It will be 20 degrees f that night. I will not start the furnace until I go to bed and it can be chilly in there for awhile until it heats up. I would like to keep the furnace set at 50 degrees after that to save power as I am sleeping.
I wonder if it is worth it or if I would be better of to just save my money and battery power to let the furnace do it's thing ?
  • Take DW, or GF, to prewarm bed. Just have her go to bed 15 min before you. Save on power, and likely more fun than 12V blanket IMO.
    Jerry
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 09, 2025
