CavemanCharlie's avatar
CavemanCharlie
Explorer III
Nov 19, 2017
12 volt heated blanket
I found a 12 volt blanket here.
https://www.amazon.com/Trillium-Worldwide-12-Volt-Heated-Blanket/dp/B0000DYVN9/ref=as_li_ss_tl?ie=UTF8&dpID=41k3kSfNSKL&dpSrc=sims&preST=_AC_UL160_SR160,160_&refRID=0C24CR7WZ37922JC3ESY&linkCode=sl1&tag=homesteaderneewssolar-20&linkId=830400d141f7f382186c4c36716535f6
It takes 50 amps but, it is only turned on for 30 to 45 minutes on a timer. Has anyone ever tried one of these out ?
I wonder if it would be worth it in my Travel Trailer when I am dry camping and using my 2, 6 volt deep cycle golf cart batteries ? I could warm up the bed with it as I go to sleep and then use my body heat to keep it warm after that.
I will be going out this Saturday night. It will be 20 degrees f that night. I will not start the furnace until I go to bed and it can be chilly in there for awhile until it heats up. I would like to keep the furnace set at 50 degrees after that to save power as I am sleeping.
I wonder if it is worth it or if I would be better of to just save my money and battery power to let the furnace do it's thing ?
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 12, 2026
