dennislanier wrote:
...As others have suggested, at LEAST 18 volts would have a better chance. In my opinion better to spend more money and be satisfied than $50 for something that probably won't work for your purposes. Over the years I have had 4 different air impacts that were rated about the same torque, and they were NOT equal in actual use, hence my statement above. I suspect the battery powered would also vary depending on the manufacturer.
..Problem with cordless battery operated units is, now you have one more battery to have to keep charged, replace every so often when it wears out, etc.
If its for something you use regularly (like for stabilizer jacks), thats not a problem. However, for something that will rarely be used (for emergencies) like is the case here, being able to use your MH's 12V power supply (or possibly 120V) is much more practical.
You think the battery in that cordless unit is going to have any power at all, when its been sitting for a few years and you get it out at the side of the road when you have a flat? Nope, it won't. Now, you have to sit at the side of the road for another 1/2 hour or so to charge it before you can do anything.
With a 12V powered unit, you can just connect it to your MH's 12V power supply and get to work. No extra batteries to have to keep charged or replace. I'm betting thats why the OP mentioned 12 volts.
Will
