lawrosa
Jun 15, 2016Explorer
13 year old trailer tires..
Well I finally got chit from the DW.. When I told her out trailer tires were from 2003 she got concerned.. I bit the bullet an replaced. If it was up to me I would have waited for a blow out.. LOLOL
Anyway I did get a flat last year with these tires but it was due to rotted valve stems. I had those all replaced. Tires were not dry rotted and had oodles of tread life left.. ( The guy before me only drove this trailer 1 week a year from NJ to PA car show in hershey PA..
That flat was while parked over the weekend at a campground..
So these are good year marathons... Nice tire IMO. I here so many blow out storys that it made me even a bit nervouse. I dont think I needed to change them but I did..
Anyway the new spare I had were the karrier loadstar load range C. Comes with rim and tire. Got them from local auto store for 79 a piece... Oreders 2 there and got another from tractor supply.
I am using one of the best looking old tire as the spare..
Also an issue I had was this year I had to turn the gain all the way up on the brake controller.. I was not able to adjust the brakes as the adjuster was frozen. So I removed the wheel and the drum to check bearings and grease adjusters.
Brakes ok but will need new next year. 37 bucks each at e trailer. I managed to lube adusters and repack the front bearings. The back bearing had some grease so instead of removing the seal I just stuck grease in the hub/bearing through the back of drum. I did repack all front bearings. They were some what dry after 13 years.. But not bad..
Pics show my worst brake set and 2003 tires and rims. ( I have been painting them yearly..
Also shows the new tires..
Did I make a good decision going with the karriers?
Date code. you also see some dry rotting on side wall...
New tires and rims
New tires and rims
