Clamon4's avatar
Clamon4
14" to 15" tires
I have a 2013 Coleman CT270BH that came with 14" rims with ST205/75/14. Can I safely upgrade to 15" rim so that I can put LT tires on her without any issues? Will I need to do an axle flip to get additional clearance? Currently there is 6" of clearance between the axles and the top of the tire and the wheel well. Also is there a standard bolt pattern for the wheels? I have looked on the website, in my paperwork and everywhere I can think of to find out the bolt pattern. The only place I haven't looked is the back of the wheel.
  • I changed out my wheels and tires after I bought my 2012 Northtrail FX235 from 14" to 15". All you need to do is check to see if the tire size you want to go to will fit and that the wheel bolt pattern is the same. I was not comfortable with the tires that came on my trailer. Weight rating was barely enough and they wore out very fast. I did a lift and upgraded to the highest weight rating and tallest tire that would fit. Saves your bearings and gives you piece of mind. I found my wheels and tires online for a great deal.
    Look online on how to measure your bolt pattern. You may or may not need to do a spring over to get the clearance for new tires and wheels. It depends on how big a tire you want to fit under your trailer.
