stevenstansfiel's avatar
Jul 29, 2017
1972 Terry Travel Pak 20 GVWR?
We bought a 1972 Terry and have peeled it back to the chassis for renovation. It was in worse shape than imagined though, and we'll be pretty much starting from scratch, but I don't know how much weight I can put on the chassis and the sticker isn't there. Anyone know the gvwr for this, or know how to find it? It's not in the owners manual, and I can't find if online anywhere.
  • Old-Biscuit wrote:
    Here is one for rent........completely renovated
    Message the owner and enquire about weight.
    Has 4000# listed
    Dry weight is listed as 3110#...2 axles
    Check sidewall of tires for MAX Load Rating....Times 4
    Check axle size.....
    An axle diameter of 1-1/2- to 1-3/4-inches usually corresponds to an axle weight rating of 1000- to 2000-lbs.
    2-3/8- up to 3-1/2-inch axles are often rated for 3500-lbs.
    Does the hot wife come with the camper rental?
  • Here is one for rent........completely renovated
    Has 4000# listed
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
