- dodge_guyExplorer IIeither measuer it or carry some gas with you, run it empty and then fill it all the way up. prepare yourself for the bill though!
- bigB42Explorermy 99 tag on wall says 80 gals but only holds 60 ken
- papocarino112Explorerits a chevy chasis that's all I can tell you,gas class a
- robatthelakeExplorerThere should be a label on the Tank, however it is likely either 90 or 100 US Gallons. Both sizes were used back then on that size rig.
Is it on a Deere Chassis ? - gboppExplorerI could bring my 96 Southwind to your house and we could transfer all the fuel from your rig into mine. Then you could go fill yours and know how much it holds. :B
My 96 holds 100 gallons in the fuel tank, but that doesn't really help you.
If you can get the dimensions of the tank, you can use The RV Doctors Formula to calculate the tank capacity.
Looking for advice before your next adventure? Look no further.25,158 PostsLatest Activity: Aug 27, 2025
