Grit_dog's avatar
Grit_dog
Navigator II
Sep 12, 2021
2-1/2” Hitch extension?
Just figgered out that my hitch shank is a bit too short. Nose cap on trailer hits the tail lights on the truck in tight turns. (Barely, just scratched not smashed, lol)
What I can’t find readily is a short 2.5” x 2.5” extension. Plenty of reducers, adapters and long 2.5” extensions, but nothing in a short 6-8” overall extension.
Anyone else bought one? Where?
Caveat just looked online. Haven’t hit up any trailer/truck shops yet.
  • At 6-8" extension, you do not have room to install the shank in the "extended" part if your intent is to maintain 2.5".
    What I did, was buy a 24" long Curt "weldable receiver tube", stuck it in my 2.5" receiver at the extension I needed (was about 12"), and marked the pin hole. Drilled on the drill press. Welded 15,000lb rated D-rings on it for the safety chains (looks totally inappropriate when viewed from above, if you get my drift). Made up short safety chains to chain the extension to the receiver, which you probably won't need for only 6-8". Painted with black epoxy appliance enamel.
    I use a standard 2" shank in the extension, and the extension goes in the 2-1/2" receiver.
    Another option presented to me was Brophy makes/made an extended shank, about 6" longer than a standard shank. BH-20 was the part number for the 2" version.
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Oct 30, 2025
