Need-A-Vacation's avatar
Jun 12, 2015
2-1/2" WD Shanks???
Who uses a 2-1/2" shank instead of the adapter sleeve, and what brand shank did you get for what brand hitch assembly?
We have a Reese trunnion system, and wonder how their #54977 shank is? Or do you guys prefer a solid, welded shank over the cast shanks?
TY!!!
  • I keep reading solid or cast. I thought cast Is solid. Maybe the question is cast or forged? Maybe cast or square tube?
    I'm used to seeing the cast vs forged debate on revolver forums, not here. :)
  • Muddy,
    I make it a habit to remove it when I pull the hitch, but know what you mean so tha k you for the reminder! Buddy forgot to remove his and for a factory sleeve it was something like $35!!! ??
    I usually leave the hitch in until I get home and unhooked unless we end up running to town for something.
    Just trying to decide if a solid or cast shank is the best way to go..... And which brand? Did notice on Etrailer Blue Ox has a solid shank. Need to verify the drop I currently have. Had a deep drop Reese for the old trailer, but between the new(er) trailer and new HD not as much drop is needed. May still get the larger drop for the "if needed in the future" I will be all set.
  • Get the 2 1/2 shank that way you don't have to worry about forgetting to take out the adapter when you remove the hitch. Kind of sucks when you have to run 2 hours to town to pick up a new adapter.
  • Hawkeye,
    Could you ask what brand shank he has if it's solid? From what I have found Reese does not have a solid 2-1/2" shank, only the cast.
    I found a solid shank made by Brophy on eBay from R&P Carriages for about $155/shipped.
    TY!!
  • My Dad has 2-1/2" shank on his Reese setup, solid, not cast. He likes it as when using the adapter, the extra play caused wear and elongated the hitch pin holes.
