rbp111 wrote:
Granted, 2 6-volt golf cart batteries last longer than 2 12-volt batteries. But what if one of the 6-volt dies, are you with out all power until a new 6-volt battery is purchased?
Well, you have two bad assumptions in that one paragraph, I will cover.
2 6 volt last longer than 2 12 volt: Generallly that is true but while when we speak of six volt we are normally talking GC-2, 230 amp hour DEEP CYCLE (115 amp hours usable) (This is at the 20 hour rate).
When we talk about 12 volt there are dozens of different batteries, Many can be had in Deep Cycle if you are willing to look hard and pay through the nose. a pair of 8D 12 volt for example, will outlast that pair of 6 volt by a factor of over 2x, (Each 8D is about the same as the six volt pair all by itself, also as heavy as the six volt pair)
Second. There are no six volt batteries in an RV, only 12 volt, some of them come in two smaller halves for ease in handling and savings in price (Since the GC-2 is the single most produced lead acid rechargable the cost per unit is lower).
So though oney one of the six volt goes bad.. Actually usually only 1/3 of it goes bad.. But that is the same as if one cell in the 12 volt (1/6tgh of the 12 volt battery) went bad.. You replace 'em both.
Now to the 'Are you out of power' question: Depends. on shore power no, the converter will continue to convert.
If you are worried about, say the time it takes you to get to Sam's club from the campground.. No reason you can not put a small 12 volt (Say a Group 27) in parallel with the six volt pair. Some folks yammer about "The smaller/larger" battery chargin faster or slower and all sorts of dire warnings.. They should really research what they are saying.
(Fact, batteries in parallel, after the first charge/discharge cycle, are always in LOCK STEP when it comes to state of charge, if one of 'em is at 99, so is the other) Yes the larger battery will take a bigger share of the charge current (and provide a bigger share when powering the loads) but it's in perfect proportion to the size)
