TurnThePage
Nov 13, 2017Explorer
The alcohol is likely not a concern. They say it to prevent drying out seals. However, I've never noticed a problem with it. One way to avoid most of these "issues" would be to simply drain the pink stuff once you've used it to winterize. Then the only places it should be is in the traps, maybe the toilet bowl and some small amount at the waste valves.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
