Dog_Trainer
Nov 15, 2017Explorer II
DrewE wrote:Grit dog wrote:
I use windshield washer fluid. 1/2 the price of the cheap stuff and it works.
Boat ballast tanks/pumps and rv drains and tanks.
If you’re pumping it thru the water lines, I’d not use it there.
If you're putting it through the supply lines, definitely do not use winter washer fluid. The antifreeze ingredient in it is usually methanol (i.e. wood alcohol), which is quite toxic.
X2 winshield washer fluid is a very bad idea. Regular washer fluid will freeze and the stuff that is freeze proof is very bad for humans.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 23, 2026
