camp-n-family
Mar 01, 2015Explorer
Larger rims will usually have lower weight ratings. Most HD trucks come with 18" rims for a reason.
If you stick with the same overall tire diameter, meaning you'd have to go with a lower profile sidewall, you won't see any degradation in performace but the ride will be harsher. If you upsize tire diameter you will see a loss in performance as you are effectively changing the gear ratio.
With 22s you will also be much more limited in tire selection and they will cost more.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
